Ошибки в логе
pomoyka
Ошибки в логе
Сообщение pomoyka » Ср июл 10, 2024 9:25 am
alma 9.4
/var/log/brainyservice/phpmyadmin_error.log
Включена фильтрация почты http://192.168.0.95:8002/?do=mailclient&module=filter
[10-Jul-2024 12:18:50 Europe/Kiev] PHP Warning: file_put_contents(/usr/share/roundcube/logs/errors.log): failed to open stream: Permission denied in /usr/share/roundcube/program/lib/Roundcube/rcube.php on line 1364
[10-Jul-2024 12:18:50 Europe/Kiev] PHP Warning: [1146] Table 'roundcubemail.collected_addresses' doesn't exist (SQL Query: SELECT * FROM `collected_addresses` WHERE `user_id` = '2' AND `type` = '2' AND ((`name` LIKE '%kate%') OR (`email` LIKE '%kate%')) AND `email` <> '' ORDER BY `name` ASC, `email` ASC LIMIT 15) in /usr/share/roundcube/program/lib/Roundcube/rcube.php on line 1487
[10-Jul-2024 12:18:57 Europe/Kiev] PHP Warning: file_put_contents(/usr/share/roundcube/logs/sendmail.log): failed to open stream: Permission denied in /usr/share/roundcube/program/lib/Roundcube/rcube.php on line 1364
[10-Jul-2024 12:18:57 Europe/Kiev] PHP Warning: file_put_contents(/usr/share/roundcube/logs/errors.log): failed to open stream: Permission denied in /usr/share/roundcube/program/lib/Roundcube/rcube.php on line 1364
[10-Jul-2024 12:18:57 Europe/Kiev] PHP Warning: [1146] Table 'roundcubemail.collected_addresses' doesn't exist (SQL Query: SELECT COUNT(`address_id`) AS cnt FROM `collected_addresses` WHERE `user_id` = '2' AND `type` = '1' AND ((`email` LIKE 'kate.color@mydomen'))) in /usr/share/roundcube/program/lib/Roundcube/rcube.php on line 1487
[10-Jul-2024 12:18:57 Europe/Kiev] PHP Warning: [1146] Table 'roundcubemail.collected_addresses' doesn't exist (SQL Query: INSERT INTO `collected_addresses` (`user_id`, `changed`, `type`, `name`, `email`) VALUES ('2', now(), '1', 'Kate Color', 'kate.color@mydomen„')) in /usr/share/roundcube/program/lib/Roundcube/rcube.php on line 1487
Re: Ошибки в логе
Сообщение alenka » Ср июл 10, 2024 10:28 am
Какая версия roundcube, какая версия базы данных, и что в фильтре?
pomoyka
Re: Ошибки в логе
Сообщение pomoyka » Ср июл 10, 2024 10:37 am
roundcube 1.5.5
mysql5.7.36
Пример фильтра
1 from=(contains'crocoweb') -> save=('.Kroco/cur/@Croco')
сам фильтр работает
Re: Ошибки в логе
Сообщение alenka » Ср июл 10, 2024 11:13 am
Я вижу что нет дампа таблицы roundcubemail.collected_addresses, это поправим.
Это не критические ошибки, а только Warning
pomoyka
Re: Ошибки в логе
Сообщение pomoyka » Ср июл 10, 2024 11:57 am
ок.Спасибо.
