Проблема в работе панели на centos7
adamzolo
Сообщение adamzolo » Вт янв 11, 2022 8:10 am
На сервер не пускает.
Возможно войти только в rescue
При обновлении зависимости
Error: Package: cloud-init-19.4-7.el7.centos.5.x86_64 (updates)
Requires: pyserial
Available: pyserial-2.6-6.el7.noarch (base)
pyserial = 2.6-6.el7
Error: Package: python2-acme-1.11.0-3.brainy.el7.noarch (brainy-python3_sb)
Requires: python2-six
** Found 7 pre-existing rpmdb problem(s), 'yum check' output follows:
systemd-219-67.el7_7.2.x86_64 has missing requires of systemd-libs = ('0', '219', '67.el7_7.2')
systemd-python-219-78.el7_9.3.x86_64 has missing requires of systemd = ('0', '219', '78.el7_9.3')
systemd-sysv-219-78.el7_9.3.x86_64 has missing requires of systemd = ('0', '219', '78.el7_9.3')
util-linux-2.23.2-61.el7.x86_64 has missing requires of libblkid = ('0', '2.23.2', '61.el7')
util-linux-2.23.2-61.el7.x86_64 has missing requires of libmount = ('0', '2.23.2', '61.el7')
util-linux-2.23.2-61.el7.x86_64 has missing requires of libsmartcols = ('0', '2.23.2', '61.el7')
util-linux-2.23.2-61.el7.x86_64 has missing requires of libuuid = ('0', '2.23.2', '61.el7')
repo
total 60
drwxr-xr-x. 2 root root 4096 Oct 1 2020 .
drwxr-xr-x. 117 root root 12288 Jan 11 08:57 ..
-rw-r--r--. 1 root root 1213 Nov 27 2019 brainy.repo
-rw-r--r-- 1 root root 1664 Nov 23 2020 CentOS-Base.repo
-rw-r--r-- 1 root root 1309 Nov 23 2020 CentOS-CR.repo
-rw-r--r-- 1 root root 649 Nov 23 2020 CentOS-Debuginfo.repo
-rw-r--r-- 1 root root 314 Nov 23 2020 CentOS-fasttrack.repo
-rw-r--r-- 1 root root 630 Nov 23 2020 CentOS-Media.repo
-rw-r--r-- 1 root root 1331 Nov 23 2020 CentOS-Sources.repo
-rw-r--r-- 1 root root 8515 Nov 23 2020 CentOS-Vault.repo
-rw-r--r-- 1 root root 616 Nov 23 2020 CentOS-x86_64-kernel.repo
Что не хватает панели для обновления?
Так из-за этого невозможно войти в панель, т.к. невозможно сменить root.
passwd root
Changing password for user root.
New password:
Retype new password:
passwd: Authentication token manipulation error
Re: Проблема в работе панели на centos7
Сообщение sbury » Чт янв 13, 2022 6:52 am
проверьте наличие свободного места на диске
df -h
проверьте права доступа для файла
ls -l /etc/shadow
установить нужные права для файла можно так
chmod 0640 /etc/shadow
проверьте в каком режиме файловая система, возможно она только для чтения
изменить режим можно командой
mount -o remount,rw /
проверьте наличие модулей аутентификации
ls /etc/pam.d/
