Не отправляет письма
Marfey
Сообщение Marfey » Сб май 02, 2020 12:46 pm
При отправки письма не отправляются. В ответ приходит письмо с текстом
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its
recipients. This is a permanent error. The following address(es) failed:
adm.kompakt@gmail.com
host gmail-smtp-in.l.google.com [64.233.165.26]
SMTP error from remote mail server after pipelined end of data:
550-5.7.26 This message does not have authentication information or fails to
550-5.7.26 pass authentication checks. To best protect our users from spam, the
550-5.7.26 message has been blocked. Please visit
550-5.7.26 https://support.google.com/mail/answer/ ... entication for more
550 5.7.26 information. h15si4194661lja.115 - gsmtp
Reporting-MTA: dns; commfort.rv.ua
Action: failed
Final-Recipient: rfc822;adm.kompakt@gmail.com
Status: 5.0.0
Remote-MTA: dns; gmail-smtp-in.l.google.com
Diagnostic-Code: smtp; 550-5.7.26 This message does not have authentication information or fails to
Тема Re: Test
Відправник adm@commfort.rv.ua
Кому Администратор Компакт
Дата Сьогодні 15:17
Return-path: <adm@commfort.rv.ua>
Received: from [127.0.0.1] (helo=commfort.rv.ua)
by commfort.rv.ua with esmtp (Exim 4.92.3)
(envelope-from <adm@commfort.rv.ua>)
id 1jUr4p-0004H9-Kr
for adm.kompakt@gmail.com; Sat, 02 May 2020 15:17:11 +0300
To: =?UTF-8?Q?=D0=90=D0=B4=D0=BC=D0=B8=D0=BD=D0=B8=D1=81=D1=82=D1=80?= =?UTF-8?Q?=D0=B0=D1=82=D0=BE=D1=80_=D0=9A=D0=BE=D0=BC=D0=BF=D0=B0=D0=BA?= =?UTF-8?Q?=D1=82?= <adm.kompakt@gmail.com>
Subject: Re: Test
X-PHP-Originating-Script: 1001:rcube.php
MIME-Version: 1.0
Content-Type: text/plain; charset=UTF-8;
format=flowed
Content-Transfer-Encoding: 8bit
Date: Sat, 02 May 2020 15:17:02 +0300
In-Reply-To: <CAE9nfaShiSdTcN_b0ZYELGA28G1syuK2svNGsw_8xJ=TUYcwRw@mail.gmail.com>
References: <CAE9nfaShiSdTcN_b0ZYELGA28G1syuK2svNGsw_8xJ=TUYcwRw@mail.gmail.com>
Message-ID: <f982e5d03251c0d334756339cc3cdac5@commfort.rv.ua>
X-Sender: adm@commfort.rv.ua
User-Agent: Roundcube Webmail/1.1.3
X-SA-Score: -0.6
Все вроди проверил. Ничего не помогло из других топиков.
pens
Re: Не отправляет письма
Сообщение pens » Ср май 20, 2020 1:12 pm
Абсолютно такая же проблема, есть решение?
Сообщение alenka » Чт май 21, 2020 9:49 am
Сообщение Akrobs » Чт май 28, 2020 9:55 pm
Вас эта строка не смущает?
