pomoyka
Сообщение pomoyka » Сб июн 22, 2024 8:43 pm
ii brainy-nginx-all-modules 2:1.22.1-10brainy3 all A meta package that installs all available Nginx modules
ii brainy-php5 5.6.40-1brainy3 amd64 PHP is an HTML-embedded scripting language. PHP attempts
to make it
ii brainy-php5-enchant 5.6.40-1brainy3 amd64 The php-enchant package contains a dynamic shared object
that will add
ii brainy-php5-fpm 5.6.40-1brainy3 amd64 PHP-FPM (FastCGI Process Manager) is an alternative PHP
FastCGI
ii brainy-php5-gd 5.6.40-1brainy3 amd64 The php-gd package contains a dynamic shared object tha
ii brainy-php5-imagick 3.4.3-1 amd64 Imagick is a native php extension to create and modify i
mages
ii brainy-php5-intl 5.6.40-1brainy3 amd64 The php-intl package contains a dynamic shared object ta
t will add
ii brainy-php5-json 5.6.40-1brainy3 amd64 The php-json package contains a dynamic shared object ta
t will add
ii brainy-php5-mbstring 5.6.40-1brainy3 amd64 The php-mbstring package contains a dynamic shared objec
t that will add
ii brainy-php5-mcrypt 5.6.40-1brainy3 amd64 The php-mcrypt package contains a dynamic shared object
that will add
ii brainy-php5-modules-base 5.6.40-1brainy3 amd64 The php-recode package contains a dynamic shared object
that will add
ii brainy-php5-mysql 5.6.40-1brainy3 amd64 The php-mysqlnd package contains a dynamic shared object
that will add
ii brainy-php5-pdo 5.6.40-1brainy3 amd64 The php-pdo package contains a dynamic shared object tha
t will add
ii brainy-php5-pgsql 5.6.40-1brainy3 amd64 The php-pgsql package add PostgreSQL database support to
PHP.
ii brainy-php5-zip 5.6.40-1brainy3 amd64 The php-zip package contains a dynamic shared object tha
t will add
ii brotli 1.0.9-2build6
pomoyka
amd64 lossless compression algorithm and format (command line
utility)
ii busybox-static 1:1.30.1-7ubuntu3 amd64 Standalone rescue shell with tons of builtin utilities
ii byobu 5.133-1 all text window manager, shell multiplexer, integrated DevOp
s environment
ii bzip2-doc 1.0.8-5build1 all high-quality block-sorting file compressor - documentati
on
ii ca-certificates 20230311ubuntu0.22.04.1 all Common CA certificates
ii certbot 1.21.0-1build1 all automatically configure HTTPS using Let's Encrypt
ii clamav-db 0.103.11.2-0brainy0.22.04 amd64 The actual virus database for clamav
ii clamav-lib 0.103.11.2-0brainy0.22.04 amd64 This package contains dynamic libraries shared between a
pplications
ii cloud-init 24.1.3-0ubuntu1~22.04.5 all initialization and customization tool for cloud instance
s
ii cloud-initramfs-copymods 0.47ubuntu1 all copy initramfs modules into root filesystem for later us
e
ii command-not-found 22.04.0 all Suggest installation of packages in interactive bash ses
sions
ii cryptsetup-initramfs 2:2.4.3-1ubuntu1.2 all disk encryption support - initramfs integration
ii curl 7.81.0-10ubuntu1.10 amd64 command line tool for transferring data with URL syntax
ii dbus-user-session 1.12.20-2ubuntu4.1 amd64 simple interprocess messaging system (systemd --user int
egration)
ii debconf 1.5.79ubuntu1 all Debian configuration management system
ii debconf-i18n 1.5.79ubuntu1 all full internationalization support for debconf
ii dirmngr 2.2.27-3ubuntu2.1 amd64 GNU privacy guard - network certificate management servi
ce
ii distro-info 1.1ubuntu0.2 amd64 provides information about the distributions' releases
ii distro-info-data 0.52ubuntu0.7 all information about the distributions' releases (data file
s)
ii dns-root-data 2023112702~ubuntu0.22.04.1 all DNS root data including root zone and DNSSEC key
ii eatmydata 130-2build1 all Library and utilities designed to disable fsync and frie
nds
ii eject 2.37.2-4ubuntu3.4
pomoyka
Сообщение pomoyka » Сб июн 22, 2024 8:45 pm
amd64 ejects CDs and operates CD-Changers under Linux
ii exim 4.96.5-1brainy0.22.04 all Exim is a message transfer agent (MTA) developed at the
University of
ii fail2ban 0.11.2-6 all ban hosts that cause multiple authentication errors
ii file 1:5.41-3ubuntu0.1 amd64 Recognize the type of data in a file using "magic" numbe
rs
ii fontconfig 2.13.1-4.2ubuntu5 amd64 generic font configuration library - support binaries
ii fontconfig-config 2.13.1-4.2ubuntu5 all generic font configuration library - configuration
ii fonts-dejavu-core 2.37-2build1 all Vera font family derivate with additional characters
ii fonts-liberation 1:1.07.4-11 all Fonts with the same metrics as Times, Arial and Courier
ii fonts-urw-base35 20200910-1 all font set metric-compatible with the 35 PostScript Level
2 Base Fonts
ii fwupd 1.7.9-1~22.04.3 amd64 Firmware update daemon
ii fwupd-signed 1.51.1~22.04.1+1.4-0ubuntu0.1 amd64 Linux Firmware Updater EFI signed binary
ii gawk 1:5.1.0-1ubuntu0.1 amd64 GNU awk, a pattern scanning and processing language
ii geoip-database 20240403-1 all IP lookup command line tools that use the GeoIP library
(country database)
ii gettext-base 0.21-4ubuntu4 amd64 GNU Internationalization utilities for the base system
ii gir1.2-freedesktop:amd64 1.72.0-1 amd64 Introspection data for some FreeDesktop components
ii gir1.2-glib-2.0:amd64 1.72.0-1 amd64 Introspection data for GLib, GObject, Gio and GModule
ii gir1.2-packagekitglib-1.0 1.2.5-2ubuntu2 amd64 GObject introspection data for the PackageKit GLib libra
ry
ii gnupg-l10n 2.2.27-3ubuntu2.1 all GNU privacy guard - localization files
ii gpg 2.2.27-3ubuntu2.1 amd64 GNU Privacy Guard -- minimalist public key operations
ii gpgconf 2.2.27-3ubuntu2.1 amd64 GNU privacy guard - core configuration utilities
ii gpgv 2.2.27-3ubuntu2.1 amd64 GNU privacy guard - signature verification tool
ii groff-base 1.22.4-8build1 amd64 GNU troff text-formatting system (base system components
ii gsasl-common 1.10.0-5 all GNU SASL platform independent files
ii httpry 0.1.8-2 amd64 HTTP logging and information retrieval tool
ii hugepages 1.0-2.brainy all This package contains yum configuration for the BrainyCP
V1 Repository, as well as the public GPG keys used to sign packages.
ii icu-devtools 70.1-2 amd64 Development utilities for International Components for U
nicode
ii imagemagick 8:6.9.11.60+dfsg-1.3ubuntu0.22.04.3 amd64 image manipulation programs -- binaries
ii imagemagick-6-common 8:6.9.11.60+dfsg-1.3ubuntu0.22.04.3 all image manipulation programs -- infrastructure
ii imagemagick-6.q16 8:6.9.11.60+dfsg-1.3ubuntu0.22.04.3 amd64 image manipulation programs -- quantum depth Q16
pomoyka
ii info 6.8-4build1 amd64 Standalone GNU Info documentation browser
ii initramfs-tools 0.140ubuntu13.4 all generic modular initramfs generator (automation)
ii initramfs-tools-core 0.140ubuntu13.4 all generic modular initramfs generator (core tools)
ii install-info 6.8-4build1 amd64 Manage installed documentation in info format
ii ipcalc2 1.0.0-1 amd64 parameter calculator for IPv4 and IPv6 addresses
ii iptables 1.8.7-1ubuntu5.2 amd64 administration tools for packet filtering and NAT
ii iputils-tracepath 3:20211215-1 amd64 Tools to trace the network path to a remote host
ii isc-dhcp-client 4.4.1-2.3ubuntu2.4 amd64 DHCP client for automatically obtaining an IP address
ii iso-codes 4.9.0-1 all ISO language, territory, currency, script codes and thei
r translations
ii keyboard-configuration 1.205ubuntu3 all system-wide keyboard preferences
ii kpartx 0.8.8-1ubuntu1.22.04.4 amd64 create device mappings for partitions
ii landscape-common 23.02-0ubuntu1~22.04.2 amd64 Landscape administration system client - Common files
ii lftp 4.9.2-1build1 amd64 Sophisticated command-line FTP/HTTP/BitTorrent client pr
ograms
ii libaacs0:amd64 0.11.1-1 amd64 free-and-libre implementation of AACS
ii libann0 1.1.2+doc-7build1 amd64 Approximate Nearest Neighbor Searching library
ii libapparmor1:amd64 3.0.4-2ubuntu2.3 amd64 changehat AppArmor library
ii libarchive13:amd64 3.6.0-1ubuntu1.1 amd64 Multi-format archive and compression library (shared lib
rary)
ii libasound2:amd64 1.2.6.1-1ubuntu1 amd64 shared library for ALSA applications
ii libasound2-data 1.2.6.1-1ubuntu1 all Configuration files and profiles for ALSA drivers
ii libatasmart4:amd64 0.19-5build2 amd64 ATA S.M.A.R.T. reading and parsing library
ii libatm1:amd64 1:2.5.1-4build2 amd64 shared library for ATM (Asynchronous Transfer Mode)
ii libatomic1:amd64 12.3.0-1ubuntu1~22.04 amd64 support library providing __atomic built-in functions
ii libattr1:amd64 1:2.5.1-1build1 amd64 extended attribute handling - shared library
ii libauthen-sasl-perl 2.1600-1.1 all Authen::SASL - SASL Authentication framework
ii libavahi-common-data:amd64 0.8-5ubuntu5.2 amd64 Avahi common data files
ii libavformat58:amd64 7:4.4.2-0ubuntu0.22.04.1
pomoyka
r translations
ograms
rary)
pomoyka
Сообщение pomoyka » Сб июн 22, 2024 8:46 pm
amd64 FFmpeg library with (de)muxers for multimedia containers
- runtime files
ii libbdplus0:amd64 0.2.0-1 amd64 implementation of BD+ for reading Blu-ray Discs
ii libbinutils:amd64 2.38-4ubuntu2.6 amd64 GNU binary utilities (private shared library)
ii libblas3:amd64 3.10.0-2ubuntu1 amd64 Basic Linear Algebra Reference implementations, shared l
ibrary
ii libblockdev2:amd64 2.26-1 amd64 Library for manipulating block devices
ii libcap-ng0:amd64 0.7.9-2.2build3 amd64 An alternate POSIX capabilities library
ii libcbor0.8:amd64 0.8.0-2ubuntu1 amd64 library for parsing and generating CBOR (RFC 7049)
ii libclone-perl 0.45-1build3 amd64 module for recursively copying Perl datatypes
ii libclucene-core1v5:amd64 2.3.3.4+dfsg-1ubuntu5 amd64 core library for full-featured text search engine (runti
me)
ii libcommon-sense-perl:amd64 3.75-2build1 amd64 module that implements some sane defaults for Perl progr
ams
ii libcrypt-openssl-random-perl 0.15-2build4 amd64 module to access the OpenSSL pseudo-random number genera
tor
ii libctf-nobfd0:amd64 2.38-4ubuntu2.6 amd64 Compact C Type Format library (runtime, no BFD dependenc
y)
ii libctf0:amd64 2.38-4ubuntu2.6 amd64 Compact C Type Format library (runtime, BFD dependency)
ii libdata-dump-perl 1.25-1 all Perl module to help dump data structures
ii libdatrie1:amd64 0.2.13-2 amd64 Double-array trie library
ii libdb5.3:amd64 5.3.28+dfsg1-0.8ubuntu3 amd64 Berkeley v5.3 Database Libraries [runtime]
ii libdbi-perl:amd64 1.643-3build3 amd64 Perl Database Interface (DBI)
ii libdbus-glib-1-2:amd64 0.112-2build1 amd64 deprecated library for D-Bus IPC
ii libde265-0:amd64 1.0.8-1ubuntu0.3 amd64 Open H.265 video codec implementation
ii libdebconfclient0:amd64 0.261ubuntu1 amd64 Debian Configuration Management System (C-implementation
library)
ii libdecor-0-0:amd64 0.1.0-3build1 amd64 client-side window decoration library
ii libdecor-0-plugin-1-cairo:amd64 0.1.0-3build1 amd64 default decoration plugin
ii libdeflate-dev:amd64 1.10-2 amd64 headers for whole-buffer compression and decompression l
ibrary
ii libdeflate0:amd64 1.10-2 amd64 fast, whole-buffer DEFLATE-based compression and decompr
ession
pomoyka
Сообщение pomoyka » Сб июн 22, 2024 8:47 pm
ii libdigest-bubblebabble-perl 0.02-2.1 all perl module to create bubble-babble fingerprints
ii libdigest-hmac-perl 1.04+dfsg-1 all module for creating standard message integrity checks
ii libdjvulibre-dev:amd64 3.5.28-2build2 amd64 Development files for the DjVu image format
ii libdjvulibre21:amd64 3.5.28-2build2 amd64 Runtime support for the DjVu image format
ii libdw1:amd64 0.186-1build1 amd64 library that provides access to the DWARF debug informai
on
ii libeatmydata1:amd64 130-2build1 amd64 Library and utilities to disable fsync and friends - sha
red library
ii libevent-2.1-7:amd64 2.1.12-stable-1build3 amd64 Asynchronous event notification library
ii libevent-core-2.1-7:amd64 2.1.12-stable-1build3 amd64 Asynchronous event notification library (core)
ii libexif-doc 0.6.24-1build1 all library to parse EXIF files (documentation)
ii libexpat1:amd64 2.4.7-1ubuntu0.3 amd64 XML parsing C library - runtime library
ii libexpat1-dev:amd64 2.4.7-1ubuntu0.3 amd64 XML parsing C library - development kit
ii libexttextcat-2.0-0:amd64 3.4.5-1build2 amd64 Language detection library
ii libexttextcat-data 3.4.5-1build2 all Language detection library - data files
ii libfido2-1:amd64 1.10.0-1 amd64 library for generating and verifying FIDO 2.0 objects
ii libfontconfig-dev:amd64 2.13.1-4.2ubuntu5 amd64 generic font configuration library - development
ii libfontconfig1:amd64 2.13.1-4.2ubuntu5 amd64 generic font configuration library - runtime
ii libfontconfig1-dev:amd64 2.13.1-4.2ubuntu5 amd64 generic font configuration library - dummy package
ii libfribidi0:amd64 1.0.8-2ubuntu3.1 amd64 Free Implementation of the Unicode BiDi algorithm
ii libfwupd2:amd64 1.7.9-1~22.04.3 amd64 Firmware update daemon library
ii libfwupdplugin5:amd64 1.7.9-1~22.04.3 amd64 Firmware update daemon plugin library
ii libgcab-1.0-0:amd64 1.4-3build2 amd64 Microsoft Cabinet file manipulation library
ii libgdbm-compat4:amd64 1.23-1 amd64 GNU dbm database routines (legacy support runtime versio
n)
ii libgdbm6:amd64 1.23-1 amd64 GNU dbm database routines (runtime version)
ii libgdk-pixbuf2.0-common 2.42.8+dfsg-1ubuntu0.3 all GDK Pixbuf library - data files
ii libgfortran5:amd64 12.3.0-1ubuntu1~22.04 amd64 Runtime library for GNU Fortran applications
ii libgirepository-1.0-1:amd64 1.72.0-1 amd64 Library for handling GObject introspection data (runtime
library)
ii libgl1:amd64 1.4.0-1 amd64 Vendor neutral GL dispatch library -- legacy GL support
ii libgl1-amber-dri:amd64 21.3.9-0ubuntu1~22.04.1 amd64 free implementation of the OpenGL API -- Amber DRI modul
es
ii libgl1-mesa-dri:amd64 23.2.1-1ubuntu3.1~22.04.2 amd64 free implementation of the OpenGL API -- DRI modules
ii libglapi-mesa:amd64 23.2.1-1ubuntu3.1~22.04.2 amd64 free implementation of the GL API -- shared library
ii libglib2.0-data 2.72.4-0ubuntu2.3 all Common files for GLib library
ii libglvnd0:amd64 1.4.0-1 amd64 Vendor neutral GL dispatch library
ii libglx-mesa0:amd64 23.2.1-1ubuntu3.1~22.04.2 amd64 free implementation of the OpenGL API -- GLX vendor libr
ary
ii libglx0:amd64 1.4.0-1 amd64 Vendor neutral GL dispatch library -- GLX support
ii libgts-0.7-5:amd64 0.7.6+darcs121130-5 amd64 library to deal with 3D computational surface meshes
ii libheif1:amd64 1.12.0-2build1 amd64 ISO/IEC 23008-12:2017 HEIF file format decoder - shared
pomoyka
Сообщение pomoyka » Сб июн 22, 2024 8:49 pm
С чем-то таким сталкивались , точно не помню что делали. Вроде ставили какую-то программу в старт после чего-то,но по-моему это был win/server.Т.е получалось что нужная прога работала в итоге, но после рестарта, система давала ей рестарт и она поднималась, но ошибка висела.Ставили при старте системы ее в конец, все взлетало без ошибок.
Сообщение sbury » Пн июн 24, 2024 7:47 am
Сервис http-init не имеет особого значения, так как генерацией сертов занимается сама панель. Я скоректирую этот момент для убунти. Пока его вывод об ошибке вы можете смело игнорировать
Сообщение sbury » Пн июн 24, 2024 9:44 am
ubunty 22 обновить пакет at
apt-get update
apt-get remove --purge at
apt-get install at
systemctl restart atd
