Ошибка обновления c alm8
mesb
Сообщение mesb » Сб ноя 08, 2025 1:05 pm
Приветствую.
Almalinux8+панель 1.0986
Споткнулась на обновлении с
dnf clean all
dnf update
AlmaLinux 8 - BaseOS 474 kB/s | 46 MB 01:39
AlmaLinux 8 - AppStream 444 kB/s | 22 MB 00:50
AlmaLinux 8 - Extras 16 kB/s | 14 kB 00:00
Brainy v8 Base 1.0 MB/s | 778 kB 00:00
Brainy v8 APP 351 kB/s | 595 kB 00:01
Brainy v8 SQL 901 kB/s | 1.6 MB 00:01
Brainy v8 PHP 1.1 MB/s | 2.1 MB 00:01
Brainy v8 Brainy 173 kB/s | 131 kB 00:00
Brainy v8 python 194 kB/s | 145 kB 00:00
Error:
Problem 1: package php74w-v8js-2.1.7-2.brainy.el8.7.4.x86_64 from @System requires libnode.so.108()(64bit), but none of the providers can be installed
- cannot install both nodejs-libs-1:24.4.1-1.module_el8.10.0+4057+983c68f6.x86_64 from AppStream and nodejs-libs-1:18.18.2-2.brainy.el8.x86_64 from @S
ystem
- cannot install both nodejs-libs-1:18.18.2-2.brainy.el8.x86_64 from 8_app and nodejs-libs-1:24.4.1-1.module_el8.10.0+4057+983c68f6.x86_64 from AppStr
eam
- cannot install the best update candidate for package php74w-v8js-2.1.7-2.brainy.el8.7.4.x86_64
- cannot install the best update candidate for package nodejs-libs-1:18.18.2-2.brainy.el8.x86_64
Problem 2: package php81w-v8js-2.1.9-2.brainy.el8.8.1.x86_64 from @System requires libnode.so.108()(64bit), but none of the providers can be installed
- cannot install both nodejs-libs-1:24.4.1-1.module_el8.10.0+4057+983c68f6.x86_64 from AppStream and nodejs-libs-1:18.18.2-2.brainy.el8.x86_64 from @System
- cannot install both nodejs-libs-1:18.18.2-2.brainy.el8.x86_64 from 8_app and nodejs-libs-1:24.4.1-1.module_el8.10.0+4057+983c68f6.x86_64 from AppStream
- package nodejs-1:24.4.1-1.module_el8.10.0+4057+983c68f6.x86_64 from AppStream requires nodejs-libs(x86-64) = 1:24.4.1-1.module_el8.10.0+4057+983c68f6, but none of the providers can be installed
- cannot install the best update candidate for package php81w-v8js-2.1.9-2.brainy.el8.8.1.x86_64
- cannot install the best update candidate for package nodejs-1:18.18.2-2.brainy.el8.x86_64
Problem 3: problem with installed package php74w-v8js-2.1.7-2.brainy.el8.7.4.x86_64
- package php74w-v8js-2.1.7-2.brainy.el8.7.4.x86_64 from @System requires libnode.so.108()(64bit), but none of the providers can be installed
- package php74w-v8js-2.1.7-2.brainy.el8.7.4.x86_64 from 8_php requires libnode.so.108()(64bit), but none of the providers can be installed
- package nodejs-full-i18n-1:24.4.1-1.module_el8.10.0+4057+983c68f6.x86_64 from AppStream requires nodejs(x86-64) = 1:24.4.1-1.module_el8.10.0+4057+983c68f6, but none of the providers can be installed
- cannot install the best update candidate for package nodejs-full-i18n-1:18.18.2-2.brainy.el8.x86_64
Problem 4: problem with installed package php81w-v8js-2.1.9-2.brainy.el8.8.1.x86_64
- package php81w-v8js-2.1.9-2.brainy.el8.8.1.x86_64 from @System requires libnode.so.108()(64bit), but none of the providers can be installed
- package php81w-v8js-2.1.9-2.brainy.el8.8.1.x86_64 from 8_php requires libnode.so.108()(64bit), but none of the providers can be installed
- package npm-1:11.4.2-1.24.4.1.1.module_el8.10.0+4057+983c68f6.noarch from AppStream requires nodejs = 1:24.4.1-1.module_el8.10.0+4057+983c68f6, but none of the providers can be installed
- cannot install the best update candidate for package npm-1:9.8.1-1.18.18.2.2.brainy.el8.x86_64
mesb
Re: Ошибка обновления c alm8
Сообщение mesb » Сб ноя 08, 2025 2:53 pm
В качестве обходного решения вижу такой вариант:
mcedit /etc/yum.repos.d/almalinux.repo
Собственно находим секцию начинающуюся с:
[AppStream]
name=AlmaLinux $releasever - AppStream
И в конце дописываем там это:
exclude=nodejs* npm*
Сообщение sbury » Сб ноя 08, 2025 5:50 pm
выполнить
yum -y remove *v8js
yum -y remove nodejs*
Переустановить в панеле nodejs и перезапустить php-fpm сессии.
mesb
Сообщение mesb » Вс ноя 09, 2025 6:25 pm
sbury писал(а): ↑
выполнить
yum -y remove *v8js
Так он тогда ноджс то накатит 24 и нпм11
Или это нормально?
mesb
Сообщение mesb » Вс ноя 09, 2025 6:36 pm
Похоже оно несмогло
%5B%7B%22comm%22%3A%22%5C%2Fusr%5C%2Flocal%5C%2Fbrainycp%5C%2Fssh%5C%2Fpacket_manager%5C%2Fnodejs%5C%2Fnodejs.sh+install%22%2C%22array_succes%22%3A%7B%22status_nodejs%22%3A%22success%2C%23stream_id%23%22%2C%22nodejs%22%3A%221%22%7D%2C%22array_start%22%3A%7B%22status_nodejs%22%3A%22inprogress%2C%23stream_id%23%22%7D%2C%22array_unsucces%22%3A%7B%22status_nodejs%22%3A%22unsuccess%2C%23stream_id%23%22%7D%2C%22test%22%3A%22Complete%22%2C%22userowner%22%3A%22root%22%7D%2C%7B%22comm%22%3A%22%5C%2Fusr%5C%2Flocal%5C%2Fbrainycp%5C%2Fssh%5C%2Fpkg_manager_init.php+-a+update_file_config%22%7D%2C%7B%22comm%22%3A%22%5C%2Fusr%5C%2Flocal%5C%2Fbrainycp%5C%2Fsrc%5C%2Fcompiled%5C%2Fphp5%5C%2Fbin%5C%2Fphp+-q++%5C%2Fusr%5C%2Flocal%5C%2Fbrainycp%5C%2Fscripts%5C%2Fcluster.php+-a+sinhronisation_cluster+-f+%27packet%27%22%7D%5D/etc/brainy/conf/streams/packet_manager2_control_176271240918578
/usr/local/brainycp/ssh/packet_manager/nodejs/nodejs.sh install
0 files removed
AlmaLinux 8 - BaseOS 516 kB/s | 46 MB 01:31
AlmaLinux 8 - AppStream 392 kB/s | 22 MB 00:56
AlmaLinux 8 - Extras 4.6 kB/s | 14 kB 00:02
Brainy v8 Base 327 kB/s | 778 kB 00:02
Brainy v8 APP 264 kB/s | 595 kB 00:02
Brainy v8 SQL 178 kB/s | 1.6 MB 00:09
Brainy v8 PHP 339 kB/s | 2.1 MB 00:06
Brainy v8 Brainy 99 kB/s | 131 kB 00:01
Brainy v8 python 93 kB/s | 145 kB 00:01
Dependencies resolved.
Package Arch Version Repo Size
Installing:
nodejs x86_64 1:24.4.1-1.module_el8.10.0+4057+983c68f6 AppStream 65 k
Installing dependencies:
nodejs-libs x86_64 1:24.4.1-1.module_el8.10.0+4057+983c68f6 AppStream 22 M
Installing weak dependencies:
nodejs-docs noarch 1:24.4.1-1.module_el8.10.0+4057+983c68f6 AppStream 5.9 M
nodejs-full-i18n x86_64 1:24.4.1-1.module_el8.10.0+4057+983c68f6 AppStream 8.3 M
npm noarch 1:11.4.2-1.24.4.1.1.module_el8.10.0+4057+983c68f6 AppStream 2.3 M
Transaction Summary
Install 5 Packages
Total download size: 39 M
Installed size: 174 M
Downloading Packages:
(1/5): nodejs-24.4.1-1.module_el8.10.0+4057+983 48 kB/s | 65 kB 00:01
(2/5): nodejs-docs-24.4.1-1.module_el8.10.0+405 288 kB/s | 5.9 MB 00:21
(3/5): npm-11.4.2-1.24.4.1.1.module_el8.10.0+40 265 kB/s | 2.3 MB 00:08
(4/5): nodejs-full-i18n-24.4.1-1.module_el8.10. 198 kB/s | 8.3 MB 00:43
(5/5): nodejs-libs-24.4.1-1.module_el8.10.0+405 269 kB/s | 22 MB 01:24
Total 459 kB/s | 39 MB 01:26
Running transaction check
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'yum clean packages'.
Complete
Run process...
Process completed.
mesb
Сообщение mesb » Вс ноя 09, 2025 6:37 pm
В днф лог увидел это
2025-11-09T21:35:27+0300 INFO Running transaction check
2025-11-09T21:35:27+0300 CRITICAL No available modular metadata for modular package 'nodejs-1:24.4.1-1.module_el8.10.0+4057+983c68f6.x86_64', it cannot be installed on the system
2025-11-09T21:35:27+0300 CRITICAL No available modular metadata for modular package 'nodejs-docs-1:24.4.1-1.module_el8.10.0+4057+983c68f6.noarch', it cannot be installed on the system
2025-11-09T21:35:27+0300 CRITICAL No available modular metadata for modular package 'nodejs-full-i18n-1:24.4.1-1.module_el8.10.0+4057+983c68f6.x86_64', it cannot be installed on the system
2025-11-09T21:35:27+0300 CRITICAL No available modular metadata for modular package 'nodejs-libs-1:24.4.1-1.module_el8.10.0+4057+983c68f6.x86_64', it cannot be installed on the system
2025-11-09T21:35:27+0300 CRITICAL No available modular metadata for modular package 'npm-1:11.4.2-1.24.4.1.1.module_el8.10.0+4057+983c68f6.noarch', it cannot be installed on the system
mesb
Сообщение mesb » Вс ноя 09, 2025 6:53 pm
Если вдруг что:
dnf module list nodejs
Last metadata expiration check: 0:01:41 ago on Sun 09 Nov 2025 09:47:17 PM +03.
Name Stream Profiles Summary
nodejs 10 [d][x] common [d], development, minimal, s2i Javascript runtime
nodejs 12 [x] common [d], development, minimal, s2i Javascript runtime
nodejs 14 [x] common [d], development, minimal, s2i Javascript runtime
nodejs 16 [x] common [d], development, minimal, s2i Javascript runtime
nodejs 18 [x] common [d], development, minimal, s2i Javascript runtime
nodejs 20 [x] common [d], development, minimal, s2i Javascript runtime
nodejs 22 [x] common, development, minimal, s2i Javascript runtime
nodejs 24 [x] common, development, minimal, s2i Javascript runtime
Hint: [d]efault, [e]nabled, [x]disabled, nstalled
Сообщение sbury » Пн ноя 10, 2025 6:12 pm
Выполнить в консоле
Установить или переустановить nodejs в Менеджере приложений
mesb
Сообщение mesb » Пн ноя 10, 2025 6:31 pm
Всё получилось, спасибо.
