Ошибка с clamav-lib
kazazuz
Re: Ошибка с clamav-lib
Сообщение kazazuz » Сб ноя 23, 2024 8:58 pm
Сб ноя 23, 2024 8:52 pm
Переставить ClamAV в Менеджере приложений
в логах переустановки
Database test passed.
bytecode.cvd updated (version: 335, sigs: 86, f-level: 90, builder: raynman)
[OK]
Lines removed succesfull
Complete
 dpkg -l | grep clam
ii  clamav                                0.103.13.2-0brainy0.22.04               amd64        Clam AntiVirus is a GPL anti-virus toolkit for UNIX. The main purpose of
ii  clamav-daemon                         0.103.13.2-0brainy0.22.04               amd64        The Clam AntiVirus Daemon
ii  clamav-db                             0.103.13.2-0brainy0.22.04               amd64        The actual virus database for clamav
ii  clamav-lib                            0.103.13.2-0brainy0.22.04               amd64        This package contains dynamic libraries shared between applications
ii  clamd                                 0.103.13.2-0brainy0.22.04               amd64        The Clam AntiVirus Daemon
ii  clamsmtp                              1.10-22ubuntu1                          amd64        virus-scanning SMTP proxy
Telegram: @kazazuz
Сообщение sbury » Вс ноя 24, 2024 4:33 am
запустите теперь
apt-get install git
kazazuz
Сообщение kazazuz » Вс ноя 24, 2024 8:22 am
запустите теперь
apt-get install git
sudo apt-get install git
Reading package lists... Done
Building dependency tree... Done
The following package was automatically installed and is no longer required:
  libssl1.0.0
Use 'apt autoremove' to remove it.
Suggested packages:
  git-daemon-run | git-daemon-sysvinit git-doc git-email git-gui gitk gitweb
  git-cvs git-mediawiki git-svn
The following packages will be upgraded:
  git
1 upgraded, 0 newly installed, 0 to remove and 313 not upgraded.
Need to get 3,165 kB of archives.
After this operation, 16.4 kB of additional disk space will be used.
Get:1 http://asi-fs-n.contabo.net/ubuntu jammy-updates/main amd64 git amd64 1:2.                                                         34.1-1ubuntu1.11 [3,165 kB]
Fetched 3,165 kB in 0s (13.5 MB/s)
(Reading database ... 104000 files and directories currently installed.)
Preparing to unpack .../git_1%3a2.34.1-1ubuntu1.11_amd64.deb ...
Unpacking git (1:2.34.1-1ubuntu1.11) over (1:2.34.1-1ubuntu1.10) ...
Setting up git (1:2.34.1-1ubuntu1.11) ...
Благодарю, вопрос исчерпан. :)
Telegram: @kazazuz
