composer install ошибка
Den
Сообщение Den » Вт мар 21, 2023 3:11 pm
Команда composer install выдаёт такую простыню:
PHP Warning:  PHP Startup: Unable to load dynamic library 'curl.so' (tried: /usr/bin/php74/lib64/php/modules/curl.so (/usr/bin/php74/lib64/php/modules/curl.so: undefined symbol: curl_mime_type),
/usr/bin/php74/lib64/php/modules/curl.so.so (/usr/bin/php74/lib64/php/modules/curl.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
Installing dependencies from lock file (including require-dev)
Verifying lock file contents can be installed on current platform.
Your lock file does not contain a compatible set of packages. Please run composer update.
  Problem 1
    - Root composer.json requires PHP extension ext-curl * but it is missing from your system. Install or enable PHP's curl extension.
To enable extensions, verify that they are enabled in your .ini files:
    - /etc/php74w/php.ini
    - /etc/php74w/php.d/1-ioncubeloader.ini
    - /etc/php74w/php.d/10-opcache.ini
    - /etc/php74w/php.d/20-bcmath.ini
    - /etc/php74w/php.d/20-bz2.ini
    - /etc/php74w/php.d/20-calendar.ini
    - /etc/php74w/php.d/20-ctype.ini
    - /etc/php74w/php.d/20-curl.ini
    - /etc/php74w/php.d/20-dba.ini
    - /etc/php74w/php.d/20-dom.ini
    - /etc/php74w/php.d/20-enchant.ini
    - /etc/php74w/php.d/20-exif.ini
    - /etc/php74w/php.d/20-ffi.ini
    - /etc/php74w/php.d/20-fileinfo.ini
    - /etc/php74w/php.d/20-ftp.ini
    - /etc/php74w/php.d/20-gd.ini
    - /etc/php74w/php.d/20-gettext.ini
    - /etc/php74w/php.d/20-gmp.ini
    - /etc/php74w/php.d/20-iconv.ini
    - /etc/php74w/php.d/20-imap.ini
    - /etc/php74w/php.d/20-intl.ini
    - /etc/php74w/php.d/20-json.ini
    - /etc/php74w/php.d/20-ldap.ini
    - /etc/php74w/php.d/20-mbstring.ini
    - /etc/php74w/php.d/20-mysqlnd.ini
    - /etc/php74w/php.d/20-odbc.ini
    - /etc/php74w/php.d/20-pdo.ini
    - /etc/php74w/php.d/20-pgsql.ini
    - /etc/php74w/php.d/20-phar.ini
    - /etc/php74w/php.d/20-posix.ini
    - /etc/php74w/php.d/20-pspell.ini
    - /etc/php74w/php.d/20-shmop.ini
    - /etc/php74w/php.d/20-simplexml.ini
    - /etc/php74w/php.d/20-snmp.ini
    - /etc/php74w/php.d/20-soap.ini
    - /etc/php74w/php.d/20-sockets.ini
    - /etc/php74w/php.d/20-sodium.ini
    - /etc/php74w/php.d/20-sqlite3.ini
    - /etc/php74w/php.d/20-sysvmsg.ini
    - /etc/php74w/php.d/20-sysvsem.ini
    - /etc/php74w/php.d/20-sysvshm.ini
    - /etc/php74w/php.d/20-tidy.ini
    - /etc/php74w/php.d/20-tokenizer.ini
    - /etc/php74w/php.d/20-xml.ini
    - /etc/php74w/php.d/20-xmlwriter.ini
    - /etc/php74w/php.d/20-xsl.ini
    - /etc/php74w/php.d/30-mysqli.ini
    - /etc/php74w/php.d/30-pdo_dblib.ini
    - /etc/php74w/php.d/30-pdo_firebird.ini
    - /etc/php74w/php.d/30-pdo_mysql.ini
    - /etc/php74w/php.d/30-pdo_odbc.ini
    - /etc/php74w/php.d/30-pdo_pgsql.ini
    - /etc/php74w/php.d/30-pdo_sqlite.ini
    - /etc/php74w/php.d/30-xmlreader.ini
    - /etc/php74w/php.d/30-xmlrpc.ini
    - /etc/php74w/php.d/40-apcu.ini
    - /etc/php74w/php.d/40-brotli.ini
    - /etc/php74w/php.d/40-env.ini
    - /etc/php74w/php.d/40-ffmpeg.ini
    - /etc/php74w/php.d/40-gearman.ini
    - /etc/php74w/php.d/40-geoip.ini
    - /etc/php74w/php.d/40-igbinary.ini
    - /etc/php74w/php.d/40-imagick.ini
    - /etc/php74w/php.d/40-mailparse.ini
    - /etc/php74w/php.d/40-mcrypt.ini
    - /etc/php74w/php.d/40-memcache.ini
    - /etc/php74w/php.d/40-msgpack.ini
    - /etc/php74w/php.d/40-ncurses.ini
    - /etc/php74w/php.d/40-psr.ini
    - /etc/php74w/php.d/40-smbclient.ini
    - /etc/php74w/php.d/40-sqlsrv.ini
    - /etc/php74w/php.d/40-ssh2.ini
    - /etc/php74w/php.d/40-swoole.ini
    - /etc/php74w/php.d/40-uploadprogress.ini
    - /etc/php74w/php.d/40-v8js.ini
    - /etc/php74w/php.d/40-yaml.ini
    - /etc/php74w/php.d/40-zephir_parser.ini
    - /etc/php74w/php.d/40-zip.ini
    - /etc/php74w/php.d/50-apc.ini
    - /etc/php74w/php.d/50-memcached.ini
    - /etc/php74w/php.d/50-phalcon.ini
    - /etc/php74w/php.d/50-redis.ini
You can also run `php --ini` in a terminal to see which files are used by PHP in CLI mode.
Alternatively, you can run Composer with `--ignore-platform-req=ext-curl` to temporarily ignore these required extensions.
Новый сервер на CentOs 7, последняя версия панели.
php по умолчанию - 7.4
Все расширения установлены и активны. Тот же curl на который оно ругается.
Что со всем этим делать?
Den
Re: composer install ошибка
Сообщение Den » Вт мар 21, 2023 6:06 pm
Вопрос снимается. Ошибки были из-за того, что пользователь был в Jail
