Не запускается панель
mortylolzteam
Сообщение mortylolzteam » Пт июл 23, 2021 11:16 am
После попытки переноса панели на другой сервер (функция панели) и редактирования IP доступа к панели (мне кажется из-за этого) перестала открываться панель, выводы команд:
[root@durex ~]# systemctl status nginxb -l
   Active: failed (Result: exit-code) since Fri 2021-07-23 14:07:21 MSK; 2min 35s ago
  Process: 814 ExecStartPre=/usr/sbin/nginxb -t (code=exited, status=1/FAILURE)
  Process: 793 ExecStartPre=/usr/bin/rm -f /run/nginxb.pid (code=exited, status=0/SUCCESS)
Jul 23 14:07:21 durex.com systemd[1]: Starting The nginx HTTP and reverse proxy server...
Jul 23 14:07:21 durex.com nginxb[814]: nginx: [emerg] invalid parameter "all/32" in /etc/brainy/src/compiled/nginxb/conf_add/api_location.conf:1
Jul 23 14:07:21 durex.com nginxb[814]: nginx: configuration file /etc/brainy/src/compiled/nginxb/nginx.conf test failed
Jul 23 14:07:21 durex.com systemd[1]: nginxb.service: control process exited, code=exited status=1
Jul 23 14:07:21 durex.com systemd[1]: Failed to start The nginx HTTP and reverse proxy server.
Jul 23 14:07:21 durex.com systemd[1]: Unit nginxb.service entered failed state.
Jul 23 14:07:21 durex.com systemd[1]: nginxb.service failed.
[root@durex ~]# systemctl status brainyphp-fpm -l
   Active: active (running) since Fri 2021-07-23 14:07:21 MSK; 6min ago
 Main PID: 758 (php-fpm)
   Status: "Processes active: 0, idle: 6, Requests: 0, slow: 0, Traffic: 0req/sec"
    Tasks: 7
   Memory: 36.6M
           ├─758 php-fpm: master process (/etc/brainy/src/compiled/php5/php-fpm.conf
           ├─900 php-fpm: pool brainy.conf
           ├─901 php-fpm: pool brainy.conf
           ├─902 php-fpm: pool brainy.conf
           ├─903 php-fpm: pool brainy.conf
           ├─905 php-fpm: pool brainyservice.conf
           └─906 php-fpm: pool brainyservice.conf
Jul 23 14:07:21 durex.com systemd[1]: Starting The Brainy-FPM PHP Process Manager...
Jul 23 14:07:21 durex.com systemd[1]: Started The Brainy-FPM PHP Process Manager.
[root@durex ~]# netstat -plunt | grep nginx
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1109/nginx: master
tcp        0      0 31.184.249.21:443       0.0.0.0:*               LISTEN      1109/nginx: master
[root@durex ~]# uname -r
3.10.0-1160.31.1.el7.x86_64
[root@durex ~]# systemctl status csf
● csf.service - ConfigServer Firewall & Security - csf
   Loaded: loaded (/usr/lib/systemd/system/csf.service; enabled; vendor preset: disabled)
   Active: failed (Result: exit-code) since Fri 2021-07-23 14:14:08 MSK; 54s ago
  Process: 14810 ExecStart=/usr/sbin/csf --initup (code=exited, status=1/FAILURE)
 Main PID: 14810 (code=exited, status=1/FAILURE)
Jul 23 14:14:08 durex.com systemd[1]: Starting ConfigServer Firewall & Security - csf...
Jul 23 14:14:08 durex.com csf[14810]: csf and lfd have been disabled, use 'csf -e' to enable
Jul 23 14:14:08 durex.com systemd[1]: csf.service: main process exited, code=exited, status=1/FAILURE
Jul 23 14:14:08 durex.com systemd[1]: Failed to start ConfigServer Firewall & Security - csf.
Jul 23 14:14:08 durex.com systemd[1]: Unit csf.service entered failed state.
Jul 23 14:14:08 durex.com systemd[1]: csf.service failed.
mortylolzteam
Re: Не запускается панель
Сообщение mortylolzteam » Пт июл 23, 2021 11:25 am
Помогло:
yum remove brainy-nginx*
yum install brainy-nginx
systemctl restart nginxb
systemctl enable nginxb
