Размер /home директории пустого пользователя больше 2.5 GB
ihortarasuk
Сообщение ihortarasuk » Ср мар 10, 2021 8:54 pm
Всем привет! Устанавливал последнюю панель на чистый Centos версии 8 и 7. Ставлю такою конфигурацию:
yum clean all && yum install -y wget && wget http://core.brainycp.com/install.sh && bash ./install.sh --package=apache2.4,nginx,php56w,php70w,php71w,php72w,php73w,php74w,php80w,bindserver,imagemagick,httpry,certbot,megacli,iotop,atop,iftop,logrotate,git,shellinabox,MariaDB10.5,phpMyAdmin-4.9.4,exim,proftpd,csf
После перезагрузки сразу падает служба rc-local
[root@static ~]# systemctl status  rc-local -l
● rc-local.service - /etc/rc.d/rc.local Compatibility
   Loaded: loaded (/usr/lib/systemd/system/rc-local.service; enabled-runtime; vendor preset: disabled)
   Active: failed (Result: exit-code) since Wed 2021-03-10 19:54:04 UTC; 48min ago
     Docs: man:systemd-rc-local-generator(8)
      CPU: 116ms
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de rc.local[5156]: umount: /home/yobane/usr/share/terminfo: not mounted.
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de rc.local[5156]: umount: /home/yobane/usr/share/zoneinfo: not mounted.
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de rc.local[5156]: umount: /home/yobane/usr/share/GeoIP: not mounted.
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de rc.local[5156]: umount: /home/yobane/usr/share/mc: not mounted.
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de rc.local[5156]: quotacheck: Skipping /dev/sda1 [/]
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de rc.local[5156]: quotacheck: Cannot find filesystem to check or filesystem not mounted with quota option.
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de systemd[1]: rc-local.service: Control process exited, code=exited status=1
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de systemd[1]: rc-local.service: Failed with result 'exit-code'.
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de systemd[1]: Failed to start /etc/rc.d/rc.local Compatibility.
Mar 10 19:54:04 static.102.133.119.168.clients.your-server.de systemd[1]: rc-local.service: Consumed 116ms CPU time
А размер каталога пользователя /home/yobane/usr/ занимает около 2.5 GB
Файловая система xfs
[root@static ~]# lsblk
NAME   MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda      8:0    0  40G  0 disk
`-sda1   8:1    0  40G  0 part /
sr0     11:0    1   4M  0 rom
[root@static ~]# cat /etc/fstab
# /etc/fstab
# Created by anaconda on Fri Dec  4 17:37:12 2020
# Accessible filesystems, by reference, are maintained under '/dev/disk/'.
# See man pages fstab(5), findfs(8), mount(8) and/or blkid(8) for more info.
# After editing this file, run 'systemctl daemon-reload' to update systemd
# units generated from this file.
UUID=efba87f2-a6d9-4aa8-9e3c-91de25086f64 /                       xfs     defaults        0 0
