Drupal
Antek
Drupal
Сообщение Antek » Вс мар 31, 2019 1:56 am
Подскажите, что при установке Drupal 7 надо дополнительно поднастраивать и как?
File system
The directory sites/default/files does not exist. An automated attempt to create this directory failed, possibly due to a permissions problem. To proceed with the installation, either create the directory and modify its permissions manually or ensure that the installer has the permissions to create it automatically. For more information, see INSTALL.txt or the online handbook.
OK
Unicode library PHP Mbstring Extension
Error
Settings file The settings file does not exist.
The Drupal installer requires that you create a settings file as part of the installation process. Copy the ./sites/default/default.settings.php file to ./sites/default/settings.php. More details about installing Drupal are available in INSTALL.txt.
