Ошибка install SSL при установке на CentOS 8
kbkit
Сообщение kbkit » Вс июн 14, 2020 8:30 pm
При установке на чистый centOS методом:
yum clean all && yum install -y wget && wget http://core.brainycp.ru/install.sh && bash ./install.sh
Выдается ошибка на шаге INSTALL SSL
Running scriptlet: wget-1.19.5-8.el8_1.1.x86_64 1/2
Running scriptlet: wget-1.19.5-7.el8_0.1.x86_64 2/2
Cleanup : wget-1.19.5-7.el8_0.1.x86_64 2/2
Verifying : wget-1.19.5-8.el8_1.1.x86_64 1/2
Verifying : wget-1.19.5-7.el8_0.1.x86_64 2/2
Upgraded:
Complete!
--2020-06-14 20:37:27-- http://core.brainycp.ru/install.sh
Resolving core.brainycp.ru (core.brainycp.ru)... 185.181.165.8
Connecting to core.brainycp.ru (core.brainycp.ru)|185.181.165.8|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 7354 (7.2K) [application/x-sh]
Saving to: 'install.sh'
install.sh 100%[===================>] 7.18K --.-KB/s in 0s
2020-06-14 20:37:27 (59.7 MB/s) - 'install.sh' saved [7354/7354]
Virtualization test: PASS
Detected OS Version: CentOS 8
Script KVM\n
Install tools network... [OK]
======= Install BRAINY ISP panel ========
======= Setup maximum configuration ========
Configure process download... [OK]
Download version... [OK]
Install BrainyCP version 1.07
Sun Jun 14 20:38:09 UTC 2020
Disable SELINUX... [OK]
Prepare install... [OK]
Configure repo... [OK]
Version os: 8
Architecture os: x86_64
Configure limits... [OK]
Configure network... [OK]
Run install script.
Install SSL... [ERROR]
uname -r
4.18.0-80.11.2.el8_0.x86_64
[root@stunning-cavallo ~]# df
devtmpfs 2002500 0 2002500 0% /dev
tmpfs 2017696 0 2017696 0% /dev/shm
tmpfs 2017696 8576 2009120 1% /run
tmpfs 2017696 0 2017696 0% /sys/fs/cgroup
/dev/sda1 59014680 926720 55545940 2% /
tmpfs 403536 0 403536 0% /run/user/0
[root@stunning-cavallo ~]# selinux
-bash: selinux: command not found
HTOP:
Re: Ошибка install SSL при установке на CentOS 8
Сообщение sbury » Пн июн 15, 2020 7:42 am
покажите вывод
yum list installed | openssl
cat /install_0.log
и еще момент. у вас отсутствует раздел swap. Это конечно не влияет на вашу ошибку, но проблемы вы с большой долей вероятности получить позже.
kbkit
Сообщение kbkit » Пн июн 15, 2020 10:39 am
1) yum list installed | openssl:
https://pastebin.com/2R7Y0VVJ
2) cat /install_0.log:
https://pastebin.com/xFzn0wsa
Сообщение sbury » Пн июн 15, 2020 10:56 am
покажите вывод
yum list installed | grep openssl
У вас ВДС или выделенный сервер? Если ыделенный, вы на нее сами устанавливали систему?
kbkit
Сообщение kbkit » Пн июн 15, 2020 11:01 am
vscale.io - vds для разработчиков (почасовая оплата).
Modular dependency problem:
Problem: conflicting requests
- nothing provides module(perl:5.26) needed by module perl-DBI:1.641:8010020191113222731:16b3ab4d-0.x86_64
openssl.x86_64 1:1.1.1-8.el8 @base
openssl-libs.i686 1:1.1.1-8.el8 @System
openssl-libs.x86_64 1:1.1.1-8.el8 @System
Сообщение sbury » Пн июн 15, 2020 11:11 am
у вас установлен мильтилибс, которые у центосовцев не совместимы. Сделайте
yum -y remove openssl-libs.i686
Покажите вывод этой команды.
И потом пробуйте запускать инсталлятор панели.
kbkit
Сообщение kbkit » Пн июн 15, 2020 10:07 pm
[root@new-zion ~]# yum -y remove openssl-libs.i686
Dependencies resolved.
Removing:
 openssl-libs                                        i686                                      1:1.1.1-8.el8                                           @System                                      3.7 M
Removing dependent packages:
 krb5-libs                                           i686                                      1.16.1-22.el8                                           @System                                      2.4 M
 libcurl                                             i686                                      7.61.1-8.el8                                            @System                                      682 k
 openldap                                            i686                                      2.4.46-9.el8                                            @System                                      1.1 M
Removing unused dependencies:
 cyrus-sasl-lib                                      i686                                      2.1.27-0.3rc7.el8                                       @System                                      723 k
 libdb                                               i686                                      5.3.28-36.el8                                           @System                                      2.1 M
 libssh                                              i686                                      0.8.5-2.el8                                             @System                                      651 k
Transaction Summary
Remove  7 Packages
Freed space: 11 M
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
  Preparing        :        1/1
  Erasing          : libcurl-7.61.1-8.el8.i686        1/7
  Erasing          : libssh-0.8.5-2.el8.i686        2/7
  Erasing          : openldap-2.4.46-9.el8.i686        3/7
  Erasing          : cyrus-sasl-lib-2.1.27-0.3rc7.el8.i686        4/7
  Running scriptlet: cyrus-sasl-lib-2.1.27-0.3rc7.el8.i686        4/7
  Erasing          : krb5-libs-1.16.1-22.el8.i686        5/7
  Erasing          : libdb-5.3.28-36.el8.i686        6/7
  Running scriptlet: libdb-5.3.28-36.el8.i686        6/7
  Erasing          : openssl-libs-1:1.1.1-8.el8.i686        7/7
  Running scriptlet: openssl-libs-1:1.1.1-8.el8.i686        7/7
  Verifying        : cyrus-sasl-lib-2.1.27-0.3rc7.el8.i686        1/7
  Verifying        : krb5-libs-1.16.1-22.el8.i686        2/7
  Verifying        : libcurl-7.61.1-8.el8.i686        3/7
  Verifying        : libdb-5.3.28-36.el8.i686        4/7
  Verifying        : libssh-0.8.5-2.el8.i686        5/7
  Verifying        : openldap-2.4.46-9.el8.i686        6/7
  Verifying        : openssl-libs-1:1.1.1-8.el8.i686        7/7
Removed:
  openssl-libs-1:1.1.1-8.el8.i686     krb5-libs-1.16.1-22.el8.i686     libcurl-7.61.1-8.el8.i686     openldap-2.4.46-9.el8.i686     cyrus-sasl-lib-2.1.27-0.3rc7.el8.i686     libdb-5.3.28-36.el8.i686
Complete!
kbkit
Сообщение kbkit » Пн июн 15, 2020 10:15 pm
Теперь ошибка dbus
Install SSL...  [OK]
Run process Haveged
Install Haveged...  [OK]
Configure Haveged...  [OK]
Mon Jun 15 22:06:01 UTC 2020
Run Install process
Install package: dbus...		 [ERROR]
An error occurred, see the log file /root/install_0.log for details.
Тут неправильный путь... должен быть /install_0.log ,и вот его вывод:
https://pastebin.com/7f82KFXx
Сообщение sbury » Пн июн 15, 2020 11:14 pm
cat /root/install_pkg_L0.log
и второе, полный вывод команды
rpm -qa | grep 686
kbkit
Сообщение kbkit » Вт июн 16, 2020 8:55 am
[root@icy-athos ~]# cat /root/install_pkg_L0.log
Error: Unknown repo: 'BaseOS'
[root@icy-athos ~]# rpm -qa | grep 686
libpsl-0.20.2-5.el8.i686
openssl-pkcs11-0.4.10-2.el8.i686
krb5-libs-1.17-18.el8.i686
libunistring-0.9.9-3.el8.i686
libidn2-2.0.5-1.el8.i686
pcre2-10.32-1.el8.i686
libsepol-2.9-1.el8.i686
libxcrypt-4.1.1-4.el8.i686
libverto-0.3.0-5.el8.i686
brotli-1.0.6-1.el8.i686
zlib-1.2.11-13.el8.i686
libselinux-2.9-3.el8.i686
glibc-2.28-42.el8.1.i686
keyutils-libs-1.5.10-6.el8.i686
libnghttp2-1.33.0-1.el8.i686
openssl-libs-1.1.1c-15.el8.i686
libcom_err-1.45.4-3.el8.i686
