Error imagemagick
YAHOO
Error imagemagick
Сообщение YAHOO » Ср ноя 08, 2017 10:32 am
Здравствуйте при установке панели на cemtos 6 x64 все проходит гладко, при установке на centos 7 x64 вылазит ошибка Install package: ImageMagick... [ERROR]
как от нее избавиться?
An error occurred, see the log file install_pkg.log for details:
Loaded plugins: fastestmirror
Determining fastest mirrors
Excluding mirror: mirror.fra10.de.leaseweb.net
* base: asi-fs-n.contabo.net
* extras: ftp.plusline.de
* updates: asi-fs-n.contabo.net
Resolving Dependencies
--> Running transaction check
---> Package NetworkManager.x86_64 1:1.8.0-9.el7 will be updated
---> Package NetworkManager.x86_64 1:1.8.0-11.el7_4 will be an update
--> Processing Dependency: NetworkManager-libnm(x86-64) = 1:1.8.0-11.el7_4 for package: 1:NetworkManager-1.8.0-11.el7_4.x86_64
---> Package NetworkManager-team.x86_64 1:1.8.0-9.el7 will be updated
---> Package NetworkManager-team.x86_64 1:1.8.0-11.el7_4 will be an update
---> Package NetworkManager-tui.x86_64 1:1.8.0-9.el7 will be updated
---> Package NetworkManager-tui.x86_64 1:1.8.0-11.el7_4 will be an update
---> Package NetworkManager-wifi.x86_64 1:1.8.0-9.el7 will be updated
---> Package NetworkManager-wifi.x86_64 1:1.8.0-11.el7_4 will be an update
---> Package NetworkManager-libnm.x86_64 1:1.8.0-9.el7 will be updated
---> Package NetworkManager-libnm.x86_64 1:1.8.0-11.el7_4 will be an update
Dependencies Resolved
Package Arch Version Repository Size
Updating:
NetworkManager x86_64 1:1.8.0-11.el7_4 updates 1.6 M
NetworkManager-team x86_64 1:1.8.0-11.el7_4 updates 156 k
NetworkManager-tui x86_64 1:1.8.0-11.el7_4 updates 224 k
NetworkManager-wifi x86_64 1:1.8.0-11.el7_4 updates 184 k
Updating for dependencies:
NetworkManager-libnm x86_64 1:1.8.0-11.el7_4 updates 1.2 M
Transaction Summary
Upgrade 4 Packages (+1 Dependent package)
Total download size: 3.4 M
Downloading packages:
Delta RPMs disabled because /usr/bin/applydeltarpm not installed.
Total 6.8 MB/s | 3.4 MB 00:00
Running transaction test
Transaction test succeeded
Running transaction
Warning: RPMDB altered outside of yum.
Updating : 1:NetworkManager-libnm-1.8.0-11.el7_4.x86_64 1/10
Updating : 1:NetworkManager-1.8.0-11.el7_4.x86_64 2/10
Updating : 1:NetworkManager-tui-1.8.0-11.el7_4.x86_64 3/10
Updating : 1:NetworkManager-team-1.8.0-11.el7_4.x86_64 4/10
Updating : 1:NetworkManager-wifi-1.8.0-11.el7_4.x86_64 5/10
Cleanup : 1:NetworkManager-tui-1.8.0-9.el7.x86_64 6/10
Cleanup : 1:NetworkManager-wifi-1.8.0-9.el7.x86_64 7/10
Cleanup : 1:NetworkManager-team-1.8.0-9.el7.x86_64 8/10
Cleanup : 1:NetworkManager-1.8.0-9.el7.x86_64 9/10
Cleanup : 1:NetworkManager-libnm-1.8.0-9.el7.x86_64 10/10
Verifying : 1:NetworkManager-tui-1.8.0-11.el7_4.x86_64 1/10
Verifying : 1:NetworkManager-team-1.8.0-11.el7_4.x86_64 2/10
Verifying : 1:NetworkManager-libnm-1.8.0-11.el7_4.x86_64 3/10
Verifying : 1:NetworkManager-1.8.0-11.el7_4.x86_64 4/10
Verifying : 1:NetworkManager-wifi-1.8.0-11.el7_4.x86_64 5/10
Verifying : 1:NetworkManager-wifi-1.8.0-9.el7.x86_64 6/10
Verifying : 1:NetworkManager-1.8.0-9.el7.x86_64 7/10
Verifying : 1:NetworkManager-libnm-1.8.0-9.el7.x86_64 8/10
Verifying : 1:NetworkManager-team-1.8.0-9.el7.x86_64 9/10
Verifying : 1:NetworkManager-tui-1.8.0-9.el7.x86_64 10/10
Updated:
Dependency Updated:
Complete!
rpm: no packages given for erase
Re: Error imagemagick
Сообщение Akrobs » Ср ноя 08, 2017 11:50 am
Странно, уже много раз устанавливал панель, такой ошибки не встречал, все пакеты установились без проблем.
CentOS 7.4 последний билд.
YAHOO
Сообщение YAHOO » Ср ноя 08, 2017 12:03 pm
CentOS Linux release 7.4.1708 (Core)
Linux vmi146686.contaboserver.net 3.10.0-693.el7.x86_64 #1 SMP Tue Aug 22 21:09:27 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
NovEes
Сообщение NovEes » Ср ноя 08, 2017 10:20 pm
Здравствуйте, такая ошибка иногда может встречаться, попробуйде на голую ОС установить то что я скинул и потом уже панель управления
    - sudo apt-get --reinstall install libept1.4.12
    - sudo apt-get install -y aptitude
    - sudo aptitude -y install imagemagick
    - sudo aptitude -y install libmagickcore-dev
    - sudo aptitude -y install libmagickwand-dev
Сообщение Akrobs » Чт ноя 09, 2017 11:10 am
Доброго дня.
Я всегда устанавливаю ПУ на чистую ОС (minimal), поэтому ошибки не встречал. Логично, что надстройки и ПУ всегда лучше устанавливать на чистую ОС.
3opan
Сообщение 3opan » Пт окт 12, 2018 8:02 pm
Тоже самое. Сервер на contabo.com. Панель не устанавливается с той же ошибкой. Как быть?
petqa
Сообщение petqa » Пт окт 12, 2018 8:09 pm
На contabo проблемы сейчас с панелью. Пытались мне починить, но не успели за день сделать. Сервер нужен был, заново поставил centos 7 и ручками поднял все окружение. Если решите проблему, отпишите, пожалуйста.
Сообщение sbury » Вс окт 14, 2018 10:48 am
Для contabo, больше не должно быть проблем с установкой. Кто сможет проверить, отпишитесь. Я думаю это должно решить проблему и на других поставщиках вдс у кого она имелась.
если у кого останется такая проблема
Дайте мне доступ по ссш. Или в личку или в нашем скайпе
Сообщение sbury » Вс окт 14, 2018 1:03 pm
не надо. это относится к debian совместимым системам . У нас red hat на rpm
3opan
Сообщение 3opan » Пн окт 15, 2018 7:33 pm
Проблема не решена. Теперь установка прерывается на
Install package: php-brainy-imagick... [error]
