nextcloud, ffmpeg
petqa
Re: nextcloud, ffmpeg
Сообщение petqa » Ср сен 26, 2018 11:01 am
Верно, nextcloud 14
~ rpm -e --nodeps libwebp
~ yum clean all && yum -y install libwebp libwebp4
Cleaning repos: base brainy-glibc_sb brainy-python3_sb extras myrepo-centos updates
Cleaning up everything
Maybe you want: rm -rf /var/cache/yum, to also free up space taken by orphaned data from disabled or removed repos
Determining fastest mirrors
Excluding mirror: mirror.fra10.de.leaseweb.net
 * base: asi-fs-n.contabo.net
 * extras: centosmirror.netcup.net
 * updates: asi-fs-n.contabo.net
base        | 3.6 kB  00:00:00
brainy-glibc_sb        | 2.9 kB  00:00:00
brainy-python3_sb        | 2.9 kB  00:00:00
extras        | 3.4 kB  00:00:00
myrepo-centos        | 2.9 kB  00:00:00
updates        | 3.4 kB  00:00:00
(1/7): base/7/x86_64/group_gz        | 166 kB  00:00:00
(2/7): brainy-python3_sb/x86_64/primary_db        | 1.2 kB  00:00:00
(3/7): brainy-glibc_sb/x86_64/primary_db        | 1.2 kB  00:00:00
(4/7): extras/7/x86_64/primary_db        | 187 kB  00:00:00
(5/7): myrepo-centos/x86_64/primary_db        | 1.6 MB  00:00:00
(6/7): updates/7/x86_64/primary_db        | 5.2 MB  00:00:00
(7/7): base/7/x86_64/primary_db        | 5.9 MB  00:00:00
369 packages excluded due to repository priority protections
Resolving Dependencies
--> Running transaction check
---> Package libwebp.x86_64 0:0.3.0-7.el7 will be installed
---> Package libwebp4.x86_64 0:0.3.0-7.el7.centos will be installed
Dependencies Resolved
 Package                                        Arch                                         Version                                                  Repository                                           Size
Installing:
 libwebp                                        x86_64                                       0.3.0-7.el7                                              base                                                170 k
 libwebp4                                       x86_64                                       0.3.0-7.el7.centos                                       myrepo-centos                                       169 k
Transaction Summary
Install  2 Packages
Total download size: 339 k
Installed size: 742 k
Downloading packages:
(1/2): libwebp-0.3.0-7.el7.x86_64.rpm        | 170 kB  00:00:00
(2/2): libwebp4-0.3.0-7.el7.centos.x86_64.rpm        | 169 kB  00:00:00
Total        1.4 MB/s | 339 kB  00:00:00
Running transaction test
Transaction check error:
  file /usr/lib64/libwebp.so.4.0.2 conflicts between attempted installs of libwebp4-0.3.0-7.el7.centos.x86_64 and libwebp-0.3.0-7.el7.x86_64
  file /usr/lib64/libwebpmux.so.0.0.0 conflicts between attempted installs of libwebp4-0.3.0-7.el7.centos.x86_64 and libwebp-0.3.0-7.el7.x86_64
Error Summary
Сообщение sbury » Ср сен 26, 2018 11:16 am
-> Проверка сценария
---> Пакет libwebp.x86_64 0:0.6.0-2.el7.centos помечен для переустановки
--> Проверка зависимостей окончена
Зависимости определены
 Package                       Архитектура                  Версия                                   Репозиторий                         Размер
Переустановка:
 libwebp                       x86_64                       0.6.0-2.el7.centos                       myrepo-centos                       252 k
Итого за операцию
Переустановить  1 пакет
Объем загрузки: 252 k
Объем изменений: 737 k
Is this ok [y/d/N]:
какаято ерунда у вас . Дайте доступ по ссш в личку
Сообщение sbury » Ср сен 26, 2018 11:43 am
сделано.
посмотрите свой файл
/etc/yum.repos.d/CentOS-Base.repo
Увас там базовых реп (Base, updates) несколько штук указано. Я оставил одну основную. Остальные , явно какие то левые прописи выставил enabled=0
После этого все пришло в норму.Пакеты установились как положено
petqa
Сообщение petqa » Ср сен 26, 2018 11:58 am
Контабо при установке ОС на своих серверах добавляет зеркала для основных репозиториев. Пакеты установились, но ffmpeg по прежнему выдает ошибку при установке.
--> Processing Dependency: python-six >= 1.4.1 for package: python2-cryptography-1.3.1-3.el7.centos.x86_64
--> Processing Dependency: python-idna >= 2.0 for package: python2-cryptography-1.3.1-3.el7.centos.x86_64
--> Processing Dependency: python-cffi >= 1.4.1 for package: python2-cryptography-1.3.1-3.el7.centos.x86_64
--> Processing Dependency: python-ipaddress for package: python2-cryptography-1.3.1-3.el7.centos.x86_64
--> Processing Dependency: python-enum34 for package: python2-cryptography-1.3.1-3.el7.centos.x86_64
Error: Package: python2-cryptography-1.3.1-3.el7.centos.x86_64 (myrepo-centos)
           Requires: python-enum34
           Requires: python-ipaddress
           Requires: python-six >= 1.4.1
           Requires: python-idna >= 2.0
           Requires: python-cffi >= 1.4.1
Интересно будут ли продолжаться данные ошибки или стоит попробовать еще раз установить панель с нуля, убрав репозитории контабо?
Можете предоставить корректный список репозиториев, который должен остаться на чистой системе для установки вашей панели?
Сообщение sbury » Ср сен 26, 2018 12:12 pm
незнаю что это за левый файл , я заменил его на стандартный центосовский
 Package                               п░я─я┘п╦я┌п╣п╨я┌я┐я─п╟        п▓п╣я─я│п╦я▐                                                п═п╣п©п╬пЇп╦я┌п╬я─п╦п╧               п═п╟пЇп╪п╣я─
пёя│я┌п╟пҐп╬п╡п╨п╟:
 ffmpeg                                x86_64             1:3.2.2-2.el7.centos                                  myrepo-centos             1.5 M
пёя│я┌п╟пҐп╬п╡п╨п╟ пЇп╟п╡п╦я│п╦п╪п╬я│я┌п╣п╧:
 SDL2                                  x86_64             2.0.3-9.el7.centos                                    myrepo-centos             341 k
 enca                                  x86_64             1.14-1.el7.centos                                     myrepo-centos             105 k
 fdk-aac                               x86_64             0.1.5-0.1.gita0bd8aa.el7.centos                       myrepo-centos             381 k
 ffmpeg-libs                           x86_64             1:3.2.2-2.el7.centos                                  myrepo-centos             6.1 M
 flac-libs                             x86_64             1.3.0-5.el7_1                                         base                      169 k
 fribidi                               x86_64             0.19.4-6.el7                                          base                       63 k
 glibmm24                              x86_64             2.50.0-1.el7                                          base                      526 k
 gsm                                   x86_64             1.0.13-11.el7                                         base                       30 k
 jack-audio-connection-kit             x86_64             1.9.10-6.el7.centos                                   myrepo-centos             540 k
 kvazaar-libs                          x86_64             1.0.0-1.el7.centos                                    myrepo-centos             191 k
 lame-libs                             x86_64             3.99.5-6.el7.centos                                   myrepo-centos             341 k
 libXi                                 x86_64             1.7.9-1.el7                                           base                       40 k
 libXtst                               x86_64             1.2.3-1.el7                                           base                       20 k
 libXv                                 x86_64             1.0.11-1.el7                                          base                       18 k
 libass                                x86_64             0.12.0-1.el7.centos                                   myrepo-centos              80 k
 libasyncns                            x86_64             0.8-7.el7                                             base                       26 k
 libavdevice                           x86_64             1:3.2.2-2.el7.centos                                  myrepo-centos              63 k
 libbluray                             x86_64             0.2.3-5.el7                                           base                      135 k
 libcdio                               x86_64             0.94-1.el7.centos                                     myrepo-centos             239 k
 libcdio-paranoia                      x86_64             10.2+0.93+1-7.el7.centos                              myrepo-centos              80 k
 libconfig                             x86_64             1.4.9-5.el7                                           base                       59 k
 libdc1394                             x86_64             2.2.2-6.el7.centos                                    myrepo-centos             120 k
 libebur128                            x86_64             1.2.2-1.el7.centos                                    myrepo-centos              17 k
 libffado                              x86_64             2.3.0-1.el7.centos                                    myrepo-centos             695 k
 libiec61883                           x86_64             1.2.0-10.el7                                          base                       37 k
 libmfx                                x86_64             1.16-2.20160317git7adf2e4.el7.centos                  myrepo-centos              29 k
 libogg                                x86_64             2:1.3.0-7.el7                                         base                       24 k
 libraw1394                            x86_64             2.1.0-2.el7                                           base                       63 k
 librtmp                               x86_64             2.4-7.el7.centos                                      myrepo-centos              70 k
 libsamplerate                         x86_64             0.1.8-6.el7                                           base                      1.0 M
 libsigc++20                           x86_64             2.10.0-1.el7                                          base                       37 k
 libsndfile                            x86_64             1.0.25-10.el7                                         base                      149 k
 libssh                                x86_64             0.7.4-1.el7.centos                                    myrepo-centos             193 k
 libtheora                             x86_64             1:1.1.1-8.el7                                         base                      136 k
 libusbx                               x86_64             1.0.21-1.el7                                          base                       61 k
 libv4l                                x86_64             0.9.5-4.el7                                           base                      194 k
 libva                                 x86_64             1.8.3-1.el7                                           base                       80 k
 libvdpau                              x86_64             1.1.1-3.el7                                           base                       34 k
 libvorbis                             x86_64             1:1.3.3-8.el7.1                                       updates                   204 k
 libxml++                              x86_64             2.40.1-2.el7.centos                                   myrepo-centos              86 k
 ocl-icd                               x86_64             2.2.9-2.el7.centos                                    myrepo-centos              41 k
 openal-soft                           x86_64             1.16.0-2.el7.centos                                   myrepo-centos             281 k
 opencore-amr                          x86_64             0.1.3-5.el7.centos                                    myrepo-centos             172 k
 openh264-libs                         x86_64             1:1.6.0-2.el7.centos                                  myrepo-centos             354 k
 openjpeg-libs                         x86_64             1.5.1-17.el7                                          base                       86 k
 opus                                  x86_64             1.2-0.2.el7.centos                                    myrepo-centos             188 k
 orc                                   x86_64             0.4.26-1.el7                                          base                      166 k
 pulseaudio-libs                       x86_64             10.0-5.el7                                            base                      651 k
 schroedinger                          x86_64             1.0.11-4.el7.centos                                   myrepo-centos             290 k
 soxr                                  x86_64             0.1.1-3.el7.centos                                    myrepo-centos              76 k
 speex                                 x86_64             1.2-0.25.rc2.el7.centos                               myrepo-centos              61 k
 tslib                                 x86_64             1.0-9.el7.centos                                      myrepo-centos              66 k
 twolame-libs                          x86_64             0.3.13-5.el7.centos                                   myrepo-centos              63 k
 vo-amrwbenc                           x86_64             0.1.3-1.el7.centos                                    myrepo-centos              70 k
 x264-libs                             x86_64             1:0.148-6.20160912git3f5ed56.el7.centos               myrepo-centos             347 k
 x265-libs                             x86_64             2.2-1.el7.centos                                      myrepo-centos             573 k
 xvidcore                              x86_64             1.3.2-6.el7.centos                                    myrepo-centos             261 k
 zvbi                                  x86_64             0.2.35-1.el7.centos                                   myrepo-centos             416 k
п≤я┌п╬пЁп╬ пЇп╟ п╬п©п╣я─п╟я├п╦я▌
пёя│я┌п╟пҐп╬п╡п╦я┌я▄  1 п©п╟п╨п╣я┌ (+58 пЇп╟п╡п╦я│п╦п╪я▀я┘)
п·п╠я┼п╣п╪ пЇп╟пЁя─я┐пЇп╨п╦: 18 M
п·п╠я┼п╣п╪ п╦пЇп╪п╣пҐп╣пҐп╦п╧: 54 M
Is this ok [y/d/N]:
пакеты готовы ставистя. Копия вашего старого в /root/REPO.c/CentOS-Base.repo
petqa
Сообщение petqa » Ср сен 26, 2018 12:16 pm
Спасибо, сейчас установился. Только вот NextCloud по прежнему не работает корректно. Буду продолжать разбираться с ним.
