Job for nginxb.service failed ... 61.177.173.50
buharin
Сообщение buharin » Пн апр 24, 2023 6:38 am
Здравствуйте!
Требования к установке соответствуют.
Ошибка во время первой установки и переустановки на этапе:
Starting Brainy SAPI...  [OK]
Starting Brainy Web Server... Job for nginxb.service failed because the control process exited with error code.
See "systemctl status nginxb.service" and "journalctl -xe" for details.
 [ERROR]
nginxb.service - The nginx HTTP and reverse proxy server
      Loaded: loaded (/usr/lib/systemd/system/nginxb.service; enabled; vendor preset: enabled)
      Active: failed (Result: exit-code) since Mon 2023-04-24 05:13:15 BST; 1min 33s ago
     Process: 4699 ExecStartPre=/usr/bin/rm -f /run/nginxb.pid (code=exited, status=203/EXEC)
         CPU: 1ms
Apr 24 05:13:15 racknerd-7cd0a5 systemd[1]: Starting The nginx HTTP and reverse proxy server...
Apr 24 05:13:15 racknerd-7cd0a5 systemd[4699]: nginxb.service: Failed to execute command: No such file or directory
Apr 24 05:13:15 racknerd-7cd0a5 systemd[4699]: nginxb.service: Failed at step EXEC spawning /usr/bin/rm: No such file or directory
Apr 24 05:13:15 racknerd-7cd0a5 systemd[1]: nginxb.service: Control process exited, code=exited, status=203/EXEC
Apr 24 05:13:15 racknerd-7cd0a5 systemd[1]: nginxb.service: Failed with result 'exit-code'.
Apr 24 05:13:15 racknerd-7cd0a5 systemd[1]: Failed to start The nginx HTTP and reverse proxy server.
journalctl -xe
Apr 24 05:13:15 racknerd-7cd0a5 systemd[1]: Started The Brainy-FPM PHP Process Manager.
-- Subject: A start job for unit brainyphp-fpm.service has finished successfully
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
-- A start job for unit brainyphp-fpm.service has finished successfully.
-- The job identifier is 2222.
Apr 24 05:13:15 racknerd-7cd0a5 systemd[1]: Reloading.
-- Subject: A start job for unit nginxb.service has begun execution
-- A start job for unit nginxb.service has begun execution.
-- The job identifier is 2291.
-- Subject: Process /usr/bin/rm could not be executed
-- The process /usr/bin/rm could not be executed and failed.
-- The error number returned by this process is ERRNO.
-- Subject: Unit process exited
-- An ExecStartPre= process belonging to unit nginxb.service has exited.
-- The process' exit code is 'exited' and its exit status is 203.
-- Subject: Unit failed
-- The unit nginxb.service has entered the 'failed' state with result 'exit-code'.
-- Subject: A start job for unit nginxb.service has failed
-- A start job for unit nginxb.service has finished with a failure.
-- The job identifier is 2291 and the job result is failed.
Apr 24 05:14:44 racknerd-7cd0a5 sshd[4705]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.50  user=root
Apr 24 05:14:46 racknerd-7cd0a5 sshd[4705]: Failed password for root from 61.177.173.50 port 27269 ssh2
Apr 24 05:14:49 racknerd-7cd0a5 sshd[4705]: Failed password for root from 61.177.173.50 port 27269 ssh2
Apr 24 05:14:51 racknerd-7cd0a5 sshd[4705]: Failed password for root from 61.177.173.50 port 27269 ssh2
Apr 24 05:14:52 racknerd-7cd0a5 sshd[4705]: Received disconnect from 61.177.173.50 port 27269:11:  [preauth]
Apr 24 05:14:52 racknerd-7cd0a5 sshd[4705]: Disconnected from authenticating user root 61.177.173.50 port 27269 [preauth]
Apr 24 05:14:52 racknerd-7cd0a5 sshd[4705]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.50  user=root
Apr 24 05:14:53 racknerd-7cd0a5 sshd[4709]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.50  user=root
Apr 24 05:14:55 racknerd-7cd0a5 sshd[4709]: Failed password for root from 61.177.173.50 port 39718 ssh2
Apr 24 05:14:58 racknerd-7cd0a5 sshd[4709]: Failed password for root from 61.177.173.50 port 39718 ssh2
Apr 24 05:15:00 racknerd-7cd0a5 sshd[4709]: Failed password for root from 61.177.173.50 port 39718 ssh2
Apr 24 05:15:01 racknerd-7cd0a5 sshd[4709]: Received disconnect from 61.177.173.50 port 39718:11:  [preauth]
Apr 24 05:15:01 racknerd-7cd0a5 sshd[4709]: Disconnected from authenticating user root 61.177.173.50 port 39718 [preauth]
Apr 24 05:15:01 racknerd-7cd0a5 sshd[4709]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.50  user=root
Помогите разобраться, как решить проблему с установкой?
Логически понимаю, что проблема с доступом по IP 61.177.173.50
После проверки что за IP 61.177.173.50 выясняется, что он находится в блок и спам листах и я не понимаю, что это за IP
Спасибо.
Re: Job for nginxb.service failed ... 61.177.173.50
Сообщение alenka » Пн апр 24, 2023 7:28 am
Используйте сборку ubuntu из официальных источников.
У вас урезанная версия. Мы уже сталкивались с данной версией, в ней нет половины симлинков на основные директории.
buharin
Сообщение buharin » Пн апр 24, 2023 1:43 pm
Устанавливается автоматически Ubuntu 20.04 64 Bit на VPS при Reinstall
У меня сейчас так:Изображение
А должно быть так?
мдя.. очень жаль, к сожалению, без понятия как на буржуйский VPS накатить 20.04.5, на которую Вы ссылаетесь ранее в подобных постах.
Может Centos таких проблем не испытывает?
Сообщение sbury » Пн апр 24, 2023 3:58 pm
Панели для работы требуется официальная версия Ubuntu 20.04 LTS.
Сообщение alenka » Пн апр 24, 2023 4:49 pm
Из того что вам предложили, ставьте на centos7
Alex39
Сообщение Alex39 » Пн апр 24, 2023 7:19 pm
Ставь на Centos 7 x64, идеально работает, проблемки есть, но решаемые.
А конкретно, на которую ставил и работает на ура CentOS-7-x86_64-Minimal-2009
buharin
Сообщение buharin » Пт июл 05, 2024 10:03 am
Здравствуйте, уважаемая alenka!
Ваши рекомендации сохраняются? А какая версия сборки на текущий момент рекомендована Ubuntu и СentOS?
Спасибо!
Сообщение alenka » Пт июл 05, 2024 10:55 am
buharin писал(а): ↑
Спасибо!
Centos прекратила поддержку 30.06.2024, в данный момент рекомендация ubuntu 22 или alma 9.4
