Не работает apache и nginx.
Andrew0002018
Сообщение Andrew0002018 » Ср сен 28, 2022 10:29 am
Я обновил панель 1.0941
Не запускается apache и nginx
Запуск неуспешный
Active: failed (Result: exit-code) since Wed 2022-09-28 13:27:23 EEST; 33ms ago
Docs: man:httpd.service(8)
Process: 17510 ExecStart=/usr/sbin/httpd $OPTIONS -DFOREGROUND (code=exited, status=1/FAILURE)
Main PID: 17510 (code=exited, status=1/FAILURE)
Status: "Reading configuration..."
Sep 28 13:27:22 systemd[1]: Starting The Apache HTTP Server...
Sep 28 13:27:23 httpd https://hostkoss.com/ [17510]: AH00526: Syntax error on line 1 of /etc/httpd/vhost.d/undefined.conf:
Sep 28 13:27:23 httpd[17510]: The address or port is invalid
Sep 28 13:27:23 systemd[1]: httpd.service: main process exited, code=exited, status=1/FAILURE
Sep 28 13:27:23 systemd[1]: Failed to start The Apache HTTP Server.
Sep 28 13:27:23 systemd[1]: Unit httpd.service entered failed state.
Sep 28 13:27:23 systemd[1]: httpd.service failed.
Запуск неуспешный
Drop-In: /usr/lib/systemd/system/nginx.service.d
└─10-limit.conf
Active: failed (Result: exit-code) since Wed 2022-09-28 13:28:37 EEST; 36ms ago
Process: 17763 ExecStartPre=/usr/sbin/nginx -t (code=exited, status=1/FAILURE)
Process: 17761 ExecStartPre=/usr/bin/rm -f /run/nginx.pid (code=exited, status=0/SUCCESS)
Sep 28 13:28:36 free.hostkoss.com systemd[1]: Starting The nginx HTTP and reverse proxy server...
Sep 28 13:28:37 free.hostkoss.com nginx[17763]: nginx: [emerg] no host in ":443" of the "listen" directive in /etc/nginx/sites-available/ssl.undefined.conf:3
Sep 28 13:28:37 nginx[17763]: nginx: configuration file /etc/nginx/nginx.conf test failed
Sep 28 13:28:37 systemd[1]: nginx.service: control process exited, code=exited status=1
Sep 28 13:28:37 systemd[1]: Failed to start The nginx HTTP and reverse proxy server.
Sep 28 13:28:37 systemd[1]: Unit nginx.service entered failed state.
Sep 28 13:28:37 systemd[1]: nginx.service failed.
Кто знает, в чем может быть проблема?
Последний раз редактировалось Andrew0002018 Чт окт 27, 2022 9:21 am, всего редактировалось 1 раз.
Re: Не работает apache и nginx.
Сообщение alenka » Ср сен 28, 2022 12:55 pm
Покажите конфиг undefined.conf и ssl.undefined.conf
по пути /etc/nginx/sites-available/ и /etc/httpd/vhost.d/
От куда у вас появились данные конфиги?
Andrew0002018
Сообщение Andrew0002018 » Ср сен 28, 2022 1:13 pm
server {
listen :443 ssl http2;
server_name ;
root ;
# ssl on;
ssl_certificate /etc/certs/unitpowe/undefined_1664310810.crt_v2;
ssl_certificate_key /etc/certs/unitpowe/undefined_1664310810.key;
#ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
#ssl_ciphers "HIGH:!RC4:!aNULL:!MD5:!kEDH";
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3;
ssl_ciphers TLS13-CHACHA20-POLY1305-SHA256:TLS13-AES-128-GCM-SHA256:TLS13-AE$
ssl_prefer_server_ciphers on;
add_header Strict-Transport-Security 'max-age=604800';
access_log /etc/nginx/vhost_logs/undefined_access;
error_log /etc/nginx/vhost_logs/undefined_error;
location ~ /.well-known { allow all; }
# location ~* robots.txt { root /etc/nginx; }
location ~ /\.ht {
deny all;
access_log off;
log_not_found off;
/etc/nginx/sites-available/undefined.conf
server {
listen :80;
server_name ;
root ;
location ~ /\.ht {
deny all;
access_log off;
log_not_found off;
location / {
root ;
proxy_pass http://:8080;
proxy_redirect off;
proxy_force_ranges on;
proxy_set_header Host $host;
перехожу сюда здесь ничего нет /etc/httpd/vhost.d/
От куда у вас появились данные конфиги? https://drive.google.com/file/d/1WOAfiY ... sp=sharing
Сообщение alenka » Ср сен 28, 2022 1:44 pm
Вывод покажите ls -al /var/brainycp/data/vhosts/
Andrew0002018
Сообщение Andrew0002018 » Ср сен 28, 2022 1:50 pm
[root@free /]# ls -al /var/brainycp/data/vhosts/
total 112
drwxr-xr-x. 2 root root 4096 Sep 28 12:33 .
drwxr-xr-x. 53 root root 4096 Sep 28 12:55 ..
-rw-r--r-- 1 root root 779 Sep 28 11:42 bkck.academy.conf
-rw-r--r-- 1 root root 501 Sep 28 12:33 !!default.conf
-rw-r--r-- 1 root root 783 Sep 28 11:42 deshevotaxi.tk.conf
-rw-r--r-- 1 root root 1130 Sep 28 11:42 dosprn.in.conf
-rw-r--r-- 1 root root 1366 Sep 28 12:20 dru-art.pp.ua.conf
-rw-r--r-- 1 root root 1448 Sep 28 11:42 eat-fit-mealplan.online.conf
-rw-r--r-- 1 root root 805 Sep 28 11:42 elmariat.com.conf
-rw-r--r-- 1 root root 1367 Sep 28 11:42 flusscrack.pp.ua.conf
-rw-r--r-- 1 root root 807 Sep 28 11:42 hokworldit.gov.ua.conf
-rw-r--r-- 1 root root 793 Sep 28 11:42 jivochat.pro.conf
-rw-r--r-- 1 root root 770 Sep 28 11:42 kovel-domofon.pp.ua.conf
-rw-r--r-- 1 root root 783 Sep 28 11:42 kvantum.online.conf
-rw-r--r-- 1 root root 798 Sep 28 11:42 notifier.pp.ua.conf
-rw-r--r-- 1 root root 797 Sep 28 11:42 novatraffictracker.tk.conf
-rw-r--r-- 1 root root 795 Sep 28 11:42 obyavlenie.gq.conf
-rw-r--r-- 1 root root 1364 Sep 28 11:42 pb-fastiv.pp.ua.conf
-rw-r--r-- 1 root root 1158 Sep 28 11:42 prodommaster.top.conf
-rw-r--r-- 1 root root 1135 Sep 28 11:42 reebok.website.conf
-rw-r--r-- 1 root root 816 Sep 28 11:42 remont-otdelka.in.ua.conf
-rw-r--r-- 1 root root 765 Sep 28 11:42 rws-test.pp.ua.conf
-rw-r--r-- 1 root root 787 Sep 28 11:42 sammarket.com.ua.conf
-rw-r--r-- 1 root root 783 Sep 28 11:42 serdar3061.com.conf
-rw-r--r-- 1 root root 791 Sep 28 11:43 test01082022.pp.ua.conf
-rw-r--r-- 1 root root 1017 Sep 28 11:43 unconquered-from-chernihiv.pp.ua.conf
-rw-r--r-- 1 root root 195 Sep 27 23:33 undefined.conf
-rw-r--r-- 1 root root 1116 Sep 28 11:43 wsty.tk.conf
Сообщение alenka » Ср сен 28, 2022 1:54 pm
total 112
Удалите файл /var/brainycp/data/vhosts/undefined.conf и пересоберите виртуальные хосты.
По ссылке :8002/index.php?do=server_control&p=0
undefined.conf у вас видимо данные webpanel brainy, и чтобы выявить ошибку нам нужно повторить данный баг.
Только что тестировала, и баг поймать не удается. Может вы скажете что именно вы делали.
Andrew0002018
Сообщение Andrew0002018 » Ср сен 28, 2022 2:20 pm
Я обновил панель и все сайты перестали работать. Зашел в админ увидел что не работает apache и nginx.
Попытался переустановить, ничего не помогает. Также я использую модуль whmcs (скачал у вас на сайте)
Модуль работает очень плохо (создает аккаунты с ошибками) Эта проблема могла возникнуть из-за того, что учетные записи создаются с ошибками.
Сообщение alenka » Ср сен 28, 2022 2:25 pm
после удаления конфига и пересборки вирт хостов апач и нгинкс заработал?
Andrew0002018
Сообщение Andrew0002018 » Ср сен 28, 2022 3:05 pm
Да спасибо, все заработало сайты работают спасибо.
