Не устанавливается certbot
minibam
Сообщение minibam » Вт мар 29, 2022 8:11 am
Проблему с разными версиями audit-libs удалось устранить, но теперь есть проблема между python3, установленным brainy, и python36, который нужен для certbot.
file /usr/lib/python3.6/site-packages/idna/__pycache__/package_data.cpython-36.opt-1.pyc conflicts between attempted installs of python3-idna-2.8-1.el7.noarch and python36-idna-2.10-1.el7.noarch
file /usr/lib/python3.6/site-packages/idna/__pycache__/package_data.cpython-36.pyc conflicts between attempted installs of python3-idna-2.8-1.el7.noarch and python36-idna-2.10-1.el7.noarch
file /usr/lib/python3.6/site-packages/idna/__pycache__/uts46data.cpython-36.opt-1.pyc conflicts between attempted installs of python3-idna-2.8-1.el7.noarch and python36-idna-2.10-1.el7.noarch
file /usr/lib/python3.6/site-packages/idna/__pycache__/uts46data.cpython-36.pyc conflicts between attempted installs of python3-idna-2.8-1.el7.noarch and python36-idna-2.10-1.el7.noarch
file /usr/lib/python3.6/site-packages/idna/core.py conflicts between attempted installs of python3-idna-2.8-1.el7.noarch and python36-idna-2.10-1.el7.noarch
file /usr/lib/python3.6/site-packages/idna/idnadata.py conflicts between attempted installs of python3-idna-2.8-1.el7.noarch and python36-idna-2.10-1.el7.noarch
file /usr/lib/python3.6/site-packages/idna/package_data.py conflicts between attempted installs of python3-idna-2.8-1.el7.noarch and python36-idna-2.10-1.el7.noarch
file /usr/lib/python3.6/site-packages/idna/uts46data.py conflicts between attempted installs of python3-idna-2.8-1.el7.noarch and python36-idna-2.10-1.el7.noarch
Обращайтесь, пожалуйста, в службу поддержки панели brainy.
minibam
Re: Не устанавливается certbot
Сообщение minibam » Вт мар 29, 2022 8:41 am
Если устанавливать через панель, тогда останавливается на этом
Стоит у меня апачи.
Transaction Summary
Install 1 Package (+62 Dependent packages)
Total size: 16 M
Installed size: 78 M
Downloading packages:
Running transaction check
Running transaction test
Сообщение alenka » Вт мар 29, 2022 9:56 am
у вас подключен сторонний репозитарий epel, удалите его, и пакеты которые установлены по зависимостям и переустановите сертбот из панели.
Панель не работает с сторонними репозитариями.
